April 05, 2006, 21:41
Tom HuberAnother Accurtron question
I have done a search and can't come up with the answer to my question. I have acquired a ladies accutron c 1974. Inside the case back, it reads--use accutron cell 221. What currently available battery equates to a 221.
April 06, 2006, 23:28
John D. DuvallTom,
To replace the old #388 mercury battery, I believe the
#329 battery will be the closest fit. However, you may have to make a small plastic shim for a snug fit.
A great place to order your watch batteries is from
jewerlysupply.comHere is a
watch battery conversion chart.Also, if the 221 is anything like the 214, don't install the battery backwards or you could do some damage.
April 07, 2006, 21:05
Tom HuberHI John, Thanks for the input. I also got a call from Frank Juchniewicz with input. Interesting to note that on the inside back cover, it specifically states to place the battery with +pole up.
April 10, 2006, 04:29
John D. DuvallTom,
Do you think the illustration presented at 'accutrons.com' is incorrect? It sure looks like the (-) is pointing out. Please let us know how it works out.
April 10, 2006, 10:36
Tom HuberHI John, THanks. I was confused. The hump side goes up. THat is the neg side. The flat side is the pos. I know the battery goes in opposite of what they go in today.
