February 11, 2019, 20:41
Mark G. ReitzWaltham 16-A canon pinion
the canon pinion on my 1944 waltham model 16-A
has become loose, this has a partially open collar
Is there anyway to safely tighten this pinion with a stake and the special stump??
Than You,Mark
February 12, 2019, 09:36
Chris AbellThere are many tools that will put a slight impression normally in the center of the pinion, just make sure you also insert something inside before crimping, I use a reamer that prevent it being crushed or overly indented.
February 12, 2019, 20:05
Mark G. ReitzThank you for your sage advice Chris, I wasn't sure
where exactly to put the indentation.
