Moseley Dustband
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/334105979
January 19, 2005, 21:11
Sam Williamson
Moseley Dustband
This old KW Elgin has a "Mosley's Pat. Sept 21,1869" dustband. My question has to do with removal. In the photo it has 2 sleightly elevated punch-outs. There are 2 sets of them as this is a 2-piece band. When I used a fingernail to test one of the little punch-outs,it broke off with just a touch of pressure. Now,how does one remove the dustbands without ruining them? I am amazed that this old movement(ca.1870) still has the apparently original band and I would like to preserve it if possible.
Sam Williamson
January 19, 2005, 21:12
Sam Williamson
Next shot, the "back end" where the 2 bands meet,as well as the engraved(or punched) Moseley name.
Sam Williamson
January 19, 2005, 21:15
Sam Williamson
A shot of the whole area. You can see the other dustband punch-outs on the left of the shot.
Sam Williamson
January 19, 2005, 22:00
Mike Miller
Sam,
If you were to remove the barrel bridge, would they slide out from the opening created by the removal of the barrel guard? It looks like the extension of two groves in the pillar plate that the bands run in.
I have never seen one of these, so this is only speculation.
January 19, 2005, 22:32
Frank Juchniewicz
Sam
Check to see if they will slide-out on the end where the two punch-outs are.I did remove one awhile ago,and I'm pretty sure they slide out of the track(trying to remember for sure).As I recall,they slide in from each end ,and meet at the middle,as your picture shows.
Frank
January 19, 2005, 22:37
Sam Williamson
Mystery solved! If you use a fine edge and insert it where the backs meet,you can slide each piece around towards the direction of the punched-out portion. Your observation of the groves on the plates enabled me to see the light! Very cool! Big Grin
Still can't believe the dustband is there after 134 years! Eek
Frank,just saw your post....and you are right! Wink
Sam Williamson
