How to remove Swiss barrel wheel cover "Click" to Login or Register
Site Moderator
Picture of John J. Flahive III
posted April 15, 2015 18:21
I'm stuck. Frown
I am working on a small Swiss HC pocket watch which just needs a cleaning. I can't figure out how to remove the barrel wheel so I can take off the bridge. The center of the barrel wheel has a cover with two open circles and a post in the middle. Does this require some special tool to disassemble?
Thanks in advance for any help you can provide.
John III
Posts: 1755 | Location: Colorado in the USA | Registered: October 17, 2005
Picture of Billy Kuhn
posted April 15, 2015 20:06
The ratchet wheel is what that wheel is called. To remove this wheel the part on to of the ratchet wheel with the two hole in it will unscrew. I have used two screw drivers to do this.
I hope this will help
Posts: 1012 | Location: Killen, Alabama in the USA | Registered: January 15, 2013
Site Moderator
posted April 16, 2015 17:30
Billy,
Thanks for the clarification and your approach to this problem. I am still not clear on how to unscrew the plate with the two holes. Can you explain what you mean by
"I have used two screw drivers to do this."
I can't get this one to budge. Does it unscrew clockwise or counterclockwise?
John
posted April 16, 2015 19:28
If you have the tapered nose wire coiling pliers they work great for these.
Ernie
Posts: 42 | Location: Manitoba in Canada | Registered: December 05, 2014
Site Moderator
posted April 16, 2015 21:04
These heavy duty curved tweezers did the trick.
Thanks guys for the ideas and help.
John III
