How to remove Swiss barrel wheel coverGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I'm stuck. I am working on a small Swiss HC pocket watch which just needs a cleaning. I can't figure out how to remove the barrel wheel so I can take off the bridge. The center of the barrel wheel has a cover with two open circles and a post in the middle. Does this require some special tool to disassemble? Thanks in advance for any help you can provide. John III | ||
The ratchet wheel is what that wheel is called. To remove this wheel the part on to of the ratchet wheel with the two hole in it will unscrew. I have used two screw drivers to do this. I hope this will help | ||||
Billy, Thanks for the clarification and your approach to this problem. I am still not clear on how to unscrew the plate with the two holes. Can you explain what you mean by "I have used two screw drivers to do this." I can't get this one to budge. Does it unscrew clockwise or counterclockwise? Thanks, John | |||
If you have the tapered nose wire coiling pliers they work great for these. Ernie | ||||
These heavy duty curved tweezers did the trick. Thanks guys for the ideas and help. John III | |||
