April 21, 2009, 13:48
Terry PittTweezers - stupid question # !
Being just a beginner I find brass tweezers a much better option than using stainless steel. They do not mark plates etc and from my perspective give a better 'feel' of what is being held/positioned, and have a lower 'ping' coefficient (where these parts go is an inigma
So why is it that there is an enormous variety of SS tweezers available vs a relatively limited variety of brass.
Brass surely is better, being softer and more easily 'dressed' than SS.
I ask, because all the better manufacturers seem to focus on SS, am I missing something here. Would appreciate the thoughts your thoughts
April 28, 2009, 22:24
Samie L. SmithBrass twezzers are good but they do have their problems ,,the biggest being thay are soft and bend easy but as you said they will not mark the plates..
July 28, 2009, 23:57
Scott CerulloHello Terri,
Brass tweezers are the way to go. No scratches, unless you are really careless. I recently attended an American Watchmakers Institute Continuing Education Course in preperation for my Certification test. Brass tweezers were required. I recall a lot of people complaining about anitmagnetic tweezers being too soft. But, once you are used to brass, you can do everything with them.
Also, no lifting of the bridges with screwdrivers. A clear lucite stick was the only thing that should be used for that purpose.
July 29, 2009, 06:50
Chris AbellAs Samie and Scott say brass tweezers are the best I use mine 95% of the time even on the smallest of movements, steel for hairspring work mainly.
here
is a link to sharpening the faces. I added sometime ago.
