March 19, 2010, 21:49
John A. Grennan IIIcase repair and plating Is it worth doing?
Any suggestions on casing replating? I have a salesmans display case that needs something done about all the brassing. Thanks.
May 01, 2010, 12:48
Tim NevinsI've been wondering the same thing. I figure there has to be platers in Phoenix to do nickel and gold.
If it can be done reasonably I'd go for it on a few of my cases. If I find anything, I'll post it here.
May 01, 2010, 14:16
Bobby Joe WilliamsonGuys, Before you have any cases replated, please do a search of this topic that has been discussed in the past. The majority opinion is the results is not satisfactory and short-lived. Click on the advanced search and go back about 1-2 years and read all you ever wanted to know about replating cases.
BJ
May 02, 2010, 20:24
Theodore J. Brown Sr.John, Tim & Bobby Joe, I agree, cases can be replated, and if done right, they will look good.But, if you carry the watch often, the new gold plate will wear off again.Gold filled and rolled gold plate cases start out with much thicker gold than electroplating can do.I have replated a few of my own cases that I really like, using a pen-plating system I got from Caswell Plating in Lyons, N.Y.It's a really good product, intended for doing small stuff, like a watch case.The color of the gold comes out a darker shade than the original case color, so I do the entire case, inside the back and bezel too.I went over them several times , to build up the gold thickness.They end up looking pretty nice, but I don't carry them very often.The ideal thing about this, is you can redo them yourself, if need be.The gold solution has a shelf life, so you have to use it before it expires.But, like everyone agrees, a replate case is never as good as as it was when new.I personally don't mind a little brass showing, especially on RR watches, since we all know they had a hard life under the worse conditions!Thanks, Ted.
May 03, 2010, 23:18
Tim NevinsI was mostly interested in nickel plating. I'll look for the gold pen, though. Thanks for the tip.
