Making Mickey Mouse HandsGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I'm working on an old Mickey Mouse pocket watch that is missing the minute hand. Lindell was kind enough to loan me an old Mickey watch that had original hands on it for a pattern. This was my first try at fabricating a minute hand from scratch and hopefully it will look okay after a paint job. I'm not sure what the original hand composition is but it appears to be some grade of steel. My MM hand was made from .020" brass plate. I'm thinking about using Testors model paint but afraid it may not adhere well to the brass. Does anyone know how best to prepare brass for paint or am I just wishing? John D. Duvall Vice President, Education ![]() | ||
John D. Can not help you with painting, but do want to compliment you on a nice job cutting out the hand. What did you use and how did you shape it? Thanks | ||||
Wayne, Thanks! Although brass is very easy to work with, the next try will probably be with steel. Brass is just too soft. I basically outlined the shape of the original hand with a scribe. I then used a Dremel grinding wheel to remove material quickly and small jeweler's files for the final work. It's not my best piece of work but from normal viewing distance it should pass the laugh test! John D. Duvall Vice President, Education ![]() | |||
John D., How ingenious of you John! Your fabrication of Mickey's arm really looks good! I'm impressed, as usual, by you and your many talents! Stephanie O'Neil NAWCC Member 143979 [This message was edited by Stephanie O'Neil on February 08, 2004 at 16:14.] | ||||
Nice job on Mickey,s hand.Did you have to prepare the brass to paint it? Is that a old watch John ? Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | ||||
Thanks Steph & Kevin. I cleaned the hand with denatured alcohol and then painted it. So far it seems to be adhering to the hand okay. I have a good scan of the seconds disc, dial and both hands for future use. John D. Duvall Vice President, Education | |||
| IHC Member 234 |
...nice piece of work JD...I think I would attempt the same if I had the Mickey '33 Ingersoll...have the Bradley pw and several wws but still looking for the Ingersoll...Jim C | |||
Jim, Thanks! Don't forget to add an old running Ingersoll dollar watch of the same vintage to your collection. You might need the movement to fix a Mickey when you find one. I believe the basic movement is the same. Just the dial and hands are different. John D. Duvall Vice President, Education | |||
