Dial feet repairGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a nice dial that has large indents in the dial feet. The screws will not hold the dial in place and it moves up and down. I am looking for a way to fill the holes so the screws will contact something and hold the dial in place. Has anyone used anything such as liquid metal or epoxy to fix a problems as this? Thanks Ed | |||
Ed, I have a box of new copper feet but you would have to solder them on. | |||
Patrick, I do not need new dial feet. The screws have made large holes in the dial feet and now they will not hold the dial tight enough. Since I have not had any responses with ideas on how to fill the holes I believe I will try epoxy and see how that will work. Thanks for your response to my request. Ed | ||||
Edward, How did it go?? Regards, Larry | |||
I am not sure it is going to work Larry. It has been about 5 hours since I put the epoxy on and it is still a little soft. I thought it would harden by now. I will check in the morning, it may be back to the drawing board. | ||||
I wish I could see just how the feet. But I HAVE very carefully pinched then just enough to get the screws to take Edward. More than once. However I am known to take chances that most wouldn't also with these watches. Regards, Larry | |||
Well, the epoxy didn't work, it never hardened. Maybe I was using the wrong type? I thought about trying to pinch the feet, but did not want to alter them. There has to be something out there that will work! | ||||
| IHC Member 1342 |
Hi, I wish I had seen this post earlier. Clean the area real well, and try JB Weld. You can use a Jewelers file to shape it when done. Feel free to email me for details if needed. Marc Micale | |||
Thanks Marc, I will give it a try! | ||||
The watch is together, the JB Weld worked great. Thanks Marc | ||||
| IHC Member 1342 |
Very good! Marc Micale | |||
