February 22, 2004, 17:53
Kevin Pestorlock springs in hunter cases
I have a 6 sz case a hunter with a broken spring the one that the case closes onto.Any thoughts on removing the spring.I had heard they are held in by screws but i am not sure.
Kevin "Veritas" West
IHC Member 261
Chapter 111,Ottawa
NAWCC Member 158976,
Nepean, Canada
February 22, 2004, 18:59
John D. DuvallKevin,
Some cases have seperate lift and catch springs. Some have one spring that incorporate both functions. Remove the bezel and look for either one or two tiny screws or pins holding the spring(s) in place.
John D. Duvall
Vice President, Education
February 22, 2004, 19:35
Kevin PestorHi John, this sz 6 has two springs, i saw a pin or two but how are the pins removed?
Thanks again for your help.
It is the catch spring that is broke, are these hard to come by?
IHC Member 261
Chapter 111,Ottawa
Nepean, Canada
February 22, 2004, 21:19
Kevin PestorI found the pin you were refering to John, pulled it out with tweezers.Now i am looking for a replacement spring.I am sure i saw some on Uncle Larry,s site.
IHC Member 261
Chapter 111,Ottawa
Nepean, Canada
February 22, 2004, 22:09
Good luck with finding the correct spring. Sometimes you can find a 6s movement in a bad hunter's case on eBay for under $25.00. If you’re lucky, you will then have a spare movement, bow, stem, sleeve, bezel, crown and latch spring for one money!
Each spring was fitted a differently by each manufacturer. You may never find a spring that will match the hole exactly in your case. You have an option of marking and drilling a new hole in the spring or drill another hole in the case to match the spring hole. The work area will be covered by the bezel anyway.
John D. Duvall
February 22, 2004, 22:28
Kevin PestorThanks John, this is a decent 15 jewel waltham movemnt so i would like to finish it and make it really nice, i hope to post pics when i get it done.
I have learned a few more new things today, fun.
IHC Member 261
Chapter 111,Ottawa
Nepean, Canada
