lock springs in hunter casesGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a 6 sz case a hunter with a broken spring the one that the case closes onto.Any thoughts on removing the spring.I had heard they are held in by screws but i am not sure. Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | |||
Kevin, Some cases have seperate lift and catch springs. Some have one spring that incorporate both functions. Remove the bezel and look for either one or two tiny screws or pins holding the spring(s) in place. John D. Duvall Vice President, Education | |||
Hi John, this sz 6 has two springs, i saw a pin or two but how are the pins removed? Thanks again for your help. It is the catch spring that is broke, are these hard to come by? Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | ||||
I found the pin you were refering to John, pulled it out with tweezers.Now i am looking for a replacement spring.I am sure i saw some on Uncle Larry,s site. Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | ||||
Kevin, Good luck with finding the correct spring. Sometimes you can find a 6s movement in a bad hunter's case on eBay for under $25.00. If you’re lucky, you will then have a spare movement, bow, stem, sleeve, bezel, crown and latch spring for one money! Each spring was fitted a differently by each manufacturer. You may never find a spring that will match the hole exactly in your case. You have an option of marking and drilling a new hole in the spring or drill another hole in the case to match the spring hole. The work area will be covered by the bezel anyway. John D. Duvall Vice President, Education | |||
Thanks John, this is a decent 15 jewel waltham movemnt so i would like to finish it and make it really nice, i hope to post pics when i get it done. I have learned a few more new things today, fun. Kevin "Veritas" West IHC Member 261 Chapter 111,Ottawa NAWCC Member 158976, Nepean, Canada | ||||
