Slot cutting for lever set watch
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/180101981
April 17, 2004, 20:37
Bruce Byrd
I unfortunately have to recase a Rockford 925. I have a nice Fahys oresilver case that it would fit into nicely. I placed the movement into the case and noticed the slot for the lever setting mechanism is just a hair to small. Can anyone give me advice on the best way to widen that slot...
April 17, 2004, 21:02
Rich Kuhn
I use a swiss pattern file for a job like that.
Rich Kuhn
IHC Member 155
April 19, 2004, 21:19
Tom Huber
I use a dremel tool, but be advised, you need a steady hand. If the tool gets away from you while cutting the notch, you can leave a pretty nasty gouge in the case.
