February 08, 2010, 14:17
Donald E. JonesHair Spring Solution
I just bought a small bottle of Anchor hair spring solution. The bottle has a dropper style nozzle. How is this solution used?
February 09, 2010, 15:26
Samie L. SmithDonald this is for cleaning hairsprings i have never used this brand what i use is a product called one dip which comes in a pint sized container.If you have a hairsping with oil the coils will stick together making the watch run fast..what i do is place some one dip in a small metal container and dip the hairsping in the solution too remove the oil..
February 09, 2010, 19:59
Donald E. JonesThanks Sammie, this is a tiny container with a nozzle that will dispense a drop at a time. I guess that a drop or two on a hairspring and a little blowing off with air might work.
February 09, 2010, 21:06
Samie L. SmithDonald that small you may be right i will check out the product online and see what and how it,s used..
February 10, 2010, 10:25
Donald E. JonesI normally use naptha, but thought I would try this product.
