March 15, 2006, 16:17
Jim CopeStaff # for E Howard 16S Series II PW
...am attempting to build a balance assembly for an E Howard 16S Series II pw but don't have access to a Howard/Keystone parts catalog to determine the staff # for starters...thanks for any help...
March 15, 2006, 17:50
John D. DuvallJim,
Does the Series II have a DR friction staff? If so, I believe its factory PN 338 or 2072. PN 341 or 2073 is listed as a SR staff.
If anyone has MS Word on their computer, try this
Helping Hand presentation on balance staffs. PN's 2072 & 2073 are from an old staff assortment listing for factory numbers.
March 15, 2006, 20:41
Jim Cope...thanks John...my dilemma is that I don't know which staff was fitted to the Howard 16S Series 11 because the watch came w/o an assembly...I have all three (#s: 338; 340; 341) Howard-Keystone staffs in stock but don't know which to target as a fit for the watch...
March 15, 2006, 21:47
John D. DuvallJim,
Look at your pallet lever assembly. Does it have a guard pin (perpendicular to the lever) or guard finger (parallel to the lever)? A guard pin would indicate a single roller is used and a finger indicates the use of a double roller. This will then help you determine which staff is needed. Also, try trimming a tiny pivot on each end of a piece of toothpick. Keep trimming one end until it just fits (with a minute amount of end play) between the plate and balance cock hole jewels. This should provide the approximate overall length of the staff or test fit one of your staffs you have in stock.
March 16, 2006, 08:20
Jim Cope....ah yes, it shud have occurred to me that the watch was fitted with a DR staff since the underslung guard finger is parallel...now while this would eliminate the SR #341 staff, I'm left w/a choice between the 2 DR staffs which are the same total length...the only significant measured difference between the two DR staffs is the size of the h'spring seat (#338F=.60 & #340=.95)...the search continues for a wheel, 'spring & DR...could turn into my life's work...
...thanks John for your help...
March 16, 2006, 15:04
John D. DuvallJim,
The 338F appears to be a friction staff and the 340, a riveted one. What year is the movement? Maybe you can narrow it down further.
March 16, 2006, 20:12
Jim Cope...the watch, a Series 11 RR Chrono has S/N:12612754 which puts it's mfr ca: 1915...now if I were a gambling man, considering that vintage, I'd bet that the right staff for the 'piece would be the friction fit 338...which would be a starting point to hopefully finding the rest of the balance ***'y parts...
March 16, 2006, 22:57
John D. DuvallJim,
I'm thinking just the reverse. Were friction fit staffs being used around 1915? I would bet on the riveted staff. Good luck in your search. Maybe a parts movement will eventually show up on eBay.
If I make it to Phoenix this month, I can always check around for you.
March 20, 2006, 22:40
Robert V. JonesHey John & Jim I have a shoe box full of American pocket watch staffs and balance jewels. I have 5 different 16 size Howard balance staffs in little envelopes but no part number just a bottle number. I like to try and help but not sure if I have what Jim needs or not. One is marked 16s Double roller with 3 in it. Let me know how I can help. Would a picture tell anything?
Oh one is marked friction!!!
March 21, 2006, 12:39
John D. DuvallThanks Robert! At this point, Jim needs a Howard 16s, balance complete that will fit his watch. All that we have determind so far is that he has a missing balance complete and a double roller movement.
