June 29, 2011, 11:51
John J. Flahive IIIMainspring Question
I haven't found the trick yet for getting the mainspring from the mainspring winder into the barrel while simultaneously getting the tab at the end of the MS into the slot on the barrel. Once the mainspring is in the barrel, I can't maneuver it to get the tab into the slot so I am forced to take the MS out again and again. Eventually I give up and have to end up putting the MS in the barrel carefully by hand.
Any suggestions?
John III
June 29, 2011, 12:27
Michael KosinenkoI use a Robbins style winder. When I wind the mainspring into the winder barrel, I leave the end with the tab or "T" end outside. I then put the winder barrel into the watch barrel while aligning the tab into the slot/hole. I then carfully place the watch barrel on the bench while keeping it in position. I then take a piece of pegwood to hold down the end of the m/s to keep it from slipping out of the slot/hole while transferring it from the winder barrel.
Mike
July 03, 2011, 05:33
John J. Flahive IIIMichael,
I got it to work by putting the tab in the slot and holding it there before pushing the mainspring off of the winder. Thanks for the help!
John III
July 03, 2011, 13:51
Michael KosinenkoI'm glad it worked. It just took a lot longer for me to explain it than you!
Mike
