hamilton model 22 box Have been looking for bottom latch for this box for a long time,Just joined club and hope I can get some information on this item. | |||
IHC Life Member |
Welcome aboard, Ronald!! I can't help with the part, but, you've come to the right place, surely someone here will be able to help. Steve | |||
Hi Steve,Hope so I have no idea where to find this part Ron. | ||||
latch | ||||
Thanks Richard,Will look that up. Ron. | ||||
IHC Member 1335![]() |
are you sure you can't repair the latch,they are very simply made??? ![]() | |||
Hi Tom,Have tried but the latch will not spring back into place when the box is closed. Ron | ||||
have you tried oiling the latch,or taking it off the box and affirming that it is straight and not bent, which could cause it to stick ![]() http://www.hamiltonparts.com/ . | |||
It appears you just have a spring problem, either broken, missing or out of alignment. | |||
latch is broken look at photo.The bottom latch has two pieces missing. | ||||
the top latch is from another model 22 deck watch and box I have. | ||||
Someone that is good at brazing might be able to fix that. I will bet Leon Harris could fix that for you! It appears you need a new spring also. https://ihc185.infopop.cc/eve/f...6013713/m/5481052062 | |||
