I am posting this in the European section just because I am guessing that is what this pocket watch is. I am unfamiliar with chronographs so I would like any help I can get. The dial is mark The Marlboro & the only marks on the movement are pat Feb 14th 88 & the numbers 4176 under the dial. The watch had four hands in the center post & then the sub second hand. It is also lever set and would have been in an open face case. Any ideas on what this is, from what I can see it appears complete other than a broken balance staff. I did remove the grears from under the dial which are only held in place by the dial. Thanks for any help you can give me. Tom ![]() | ||
Movement ![]() | |||
Movement front ![]() | |||
