March 19, 2007, 19:12
Stephan GaalAlpina Pocket Watch
I have in my collection a pocket watch marked Alpina. I believe Alpina was a selling banner with a number of companies making their watches but I am not positive of my facts. This particular watch is 53mm outside diameter with a 42mm gold coloured metal dial. Case is well used but appears to be origional to watch. The watch is thin at just over 10mm overall thickness. It is either rolled gold or plated gold as there is some brassing at winding stem. Nothing on case about what it is made from. Inside of lid has a trademark consisting of a triangle with a circle inside touching the sides. 3 small stars under base. Under stars is name Alpina in script. Matches name on dial. Under back lid is same as front but also has Garanti and 25 Jahre. Could this be a 25 year case? Movement appears to be 15 jewels but not marked. Has a model no just above small winding gears of 236. Marked Alpina just next to serial no. Finally the serial number is 0000058. Could this be classed as an early example of a whole lot that were made or is this just optamistic thinking by the maker. I would love to know more, especially when this was made.
Yet to decide it's fate.
March 19, 2007, 19:17
Stephan GaalMovement details. The blue bits are actually silver. Went blue when I enhanced the picture to show the numbers.
March 20, 2007, 08:57
Sheila GilbertRead their History Here! I bet they could tell you about your watch!
In 1901, the name "Alpina" was registered as a trademark at the same time; it would only appear on the dials of high-end watches. From the beginning, Alpina watches were manufactured with high quality components, amongst others Brequet spirals, balance wheels with gold screws and heavy gold cases.
Today each watch is still individually assembled by hand.
See all of it here
http://www.alpina-watches.com/corporate/Company.asp?key=2&sub=21&Id=1October 19, 2007, 04:40
Stephan GaalFound my first post when I was looking for something else so I got rid of the second one. I think they call this a senior's moment. Sheila, thanks for the link. Will see if I can find out more from there. At first glance it appears to deal mainly with wrist watches but does have a bit of background about the company. It all helps.
I have sent them an email with a couple of questions. Will let you know if they reply.
November 01, 2007, 07:11
Sheila GilbertStephen,
I found another of my trademark books and Alpina is listed as:
Union Horologere S.A. Bienne Switzerlans
The notes:
Filed: March 21, 1924
Use Since 1896
Claim: Watches
The information is frome the United States Horological Trademark Index by Kurtis Meyers
