Anyone into the Russian made Molnija's
February 26, 2010, 16:41
Roland GlennAnyone into the Russian made Molnija's
Just wondering as I've got a few and finally found an older 16s with only 15j from 1951. Most are the later 18j 3602 movement and in a hunter type case, whereas this one is open face and made for their home market with CCCP and not Made in USSR which was for export. I end up using these Molnias or Marathon as they were know over here as a daily pocket watch when I'm doing construction since they are cheap to buy and can take a knock or too.
Thx, Roland.
 R. Glenn
February 26, 2010, 16:42
Roland GlennHere's the 15 jewel movement.
 R. Glenn
February 26, 2010, 16:44
Roland GlennNow here's a later 18j from 1968 with a rare regulator as most later versions from the 60's and 70's have a real dinky star type regulator.
 R. Glenn
Roland Glenn1968 movement
 R. Glenn
February 26, 2010, 16:46
Roland GlennAnd here's a North America version also from 1968 with Marathon on the dial and USSR and not CCCP in those chrome looking semi-hunter cases that we've all seen over the years.
 R. Glenn
February 26, 2010, 16:47
Roland GlennMarathon 3602 movement with standard regulator.
 R. Glenn
March 16, 2010, 08:49
Krister OlssonHi Roland
I have a couple of Russian watches to. The first picture show two identical Molnias except for the dial.
March 16, 2010, 08:50
Krister OlssonAnd here is the case backs of the same.
March 16, 2010, 08:51
Krister OlssonThis is another ruski.
March 16, 2010, 08:52
Krister OlssonClose up.
March 16, 2010, 08:53
Krister OlssonAnd then comes the Ruco.
March 16, 2010, 08:54
Krister OlssonCloser.
March 16, 2010, 08:58
Krister OlssonSame movement in all of them. The Molnija 3602 with 18 jewels. Or SU 3602 as it says on one of them.
March 16, 2010, 08:59
Krister OlssonAnd again.
Regards Krister
March 16, 2010, 14:16
Roland GlennGreat images Krister. The watches with USSR on the dial are the ones for export and your one with CCCP is for their home market. I found an image of a 1940's Rolex Caliber 5513 that Molnija basically copied. That explains why these Russian pocket watches actually keep very good time for a fraction of the price.
Roland.
 R. Glenn
March 16, 2010, 15:34
John WoolseyGreat images Krister!
I've always been quite impressed with the quality of Russian made watches, the movements not only go well and keep good time, but look good too.
Sekonda stuff is very similar too, although I've only messed around with their wristwatches.
A friend told me a while back that Russian watch manufacturers bought the old machinery from Swiss makers when all their stuff was updated.
No idea if there's any truth in it, but considering the closeness of appearance to Swiss calibres, it has some credence.
John
March 16, 2010, 17:21
Krister Olssonquote:
Roland, you are sure it´s not the other way round?
Anyway,they are very sturdy and reliable watches and I´ve used them as my day-to-day carry on and off.
BTW thank you and John for the kind words.
Regards Krister
March 16, 2010, 21:17
Roland GlennHard to say Krister. The Molnija factory #2 didn't start up until 1947 and that was the sole factory for just these movements. And this Rolex is older, so again like John mentioned they may have bought the old tooling, much like what became of Hampden. Factory #2 is actually stamped on the earlier Molnija movements. Its part of a stamp that looks like a half gear with a small 3 and large 2 and then small 4. If the movement came from say factory 3 it would be the larger on the stamping.
I almost bought a 1948 15j molnija last week but fell at sleep on the bid button and it went for 25 bucks and was near mint.
Such is life.
Roland.
 R. Glenn
March 17, 2010, 10:52
Krister OlssonRoland
Thank you for the additional information on Molnijas. Of course Rolex is the original in this case. I was just kidding, hence the smiley. John is most likely right about the Russians buying tools and machinery. They have done that on other occasions such as the FIAT plant they set up in Togliattigrad.
Regards Krister
March 17, 2010, 16:33
Roland GlennTrue enough, who can forget the Lada? I can
 R. Glenn
March 18, 2010, 23:29
Scott A. WhitteyI will have to add that these watches are pretty much bullet proof I know of one that was picked up in Turkey about 1991 and has survived numerous excursions through several different washing machines .Each time the water would be drained the movement dried. Neal will just wind her up and she takes off running, still keeping time to Railroad standards.
March 19, 2010, 11:28
Roland GlennHi Scott, they are pretty robust I admit and keep very good time. I use mine as daily drivers on the construction site as they do get knocked around yet keep on running. I have one that the dial is totally worn off as the numbers are just screened on and any form of cleaning will take them right off, so I had to paint markers on it. Not pretty, but till I come across a spare old 1950's dial it'll do and my some carries it. I know that Molnija markets these pocket watches like crazy and for all types of past events. Kind of like what Westclox and Ingersoll did back in their days. I some ways these Russian pocket watches are like a high grade dollar watches of the past 50 years. Their newest types from the 1980's had a low cost brass movement, and then went to quartz with date. Still very similar to the popular 3602 movement, just now with a battery.
Roland
 R. Glenn
