May 01, 2009, 23:20
Jon Harting18K Breitling pocket watch info/help
I just came home from an auction preview where they have a 12 size, solid 18K gold Breitling pocket watch. It is in a hunter case that has blue/green enamel surrounded by fancy engraving, fleur de lis and other fancy stuff with 8 diamonds in the center on both front and back. The watch is key wind and key set. Serial number is 28488. When you move the watch around, the pattern in the enamel changes like a hologram. The second hand is missing but the watch runs. The movement is beautiful but plain gilded. I didn't have a camera so no pictures. The back of the cuvette is engraved with the number, then "Breitling Laederich, Chaux De Fonds and a personal inscription.
Does anyone have any info on key wind/set Breitling pocket watches? I feel that it's a pretty high end watch and the auction is tomorrow.
Thanks, Jon
May 02, 2009, 04:57
Gerald ZimmermannJon
Without pictures it is a hard try to answer and a little bit out of the blue but let's have a try.
What you describe is a genuine swiss watch, dating to the 1850' with translucent enamel (turquoise) over a golden background pattern.
The name Breitling-Laederich is well known but it has no known connection to the 'Breitling'firm. So if you are interrested on this watch bit on the watch, not on the name!. I fear this watch will prize high with someone on the 'Breitling','R...x' or other high brand name hype train.
Not knowing exacly what you have seen it may be usefull to check one of the past Jones & Horan auction picture (or other similiar source) for resemling watches to get a feeling for the value
Regards Gerald
May 02, 2009, 19:43
Jon HartingGerald,
Thank you for the information. I will be at the auction in about one hour and will just "play it by ear". I'll let you know what happens.
Jon
May 04, 2009, 06:47
Jon HartingWell, I decided not to bid and the watch finally sold for $600.
May 04, 2009, 07:54
Gerald ZimmermannThank you for the information.
