European Pocket Watch Forum
Tight BezelGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hi Can someone help me out on this, I put this watch in to a watch repairers hands in Feb, for a clean and service, Got it back today minus the second hand, it’s keeping good time, I have a couple of second hands that may fit ? But I can’t get the bezel off don’t know whether it is a snap on or a screw on, any ideas that may help would be appreciated ![]() | |||
face ![]() | ||||
side ![]() | ||||
| IHC Member 1101 Site Moderator |
Leslie, It looks like a snap on bezel and near the 1 O'clock position can you see a slight opening between the case and bezel? If so, this is were a case knife would be used to get in and pop the bezel off. You can also use a pocket knife but be careful and don't cut yourself. If you just had it cleaned and the bezel won't budge trying to unscrew it, then it is probably a snap on bezel. Steve | |||
Hi I agree. It´s probably a snap on bezel. If you can´t find an opening at one o´clock, just check the rest of the perimeter. The cut or what´s it called is on the bezel and can therefore be anywhere. If you use anything but a case knife, make sure it´s not too sharp because not only can you hurt yourself but you will scratch the case and/or the dial. Krister | |||
