Requesting help with Angelus alarm pocket watch "Click" to Login or Register
posted June 25, 2018 22:10
Hello All:
I am trying to disassemble what I believe is a Angelus alarm pocket watch, calibre SF 125.
The motion works came out with little trouble, but the alarm works are located on the dial side of the bottom plate and there is no obvious way to remove the dial to get at it.
There are no dial screws around the edge. The enclosed photo will (hopefully) show a post, the setting lever and something that interacts with the winding stem (l to r). These are the only parts on the edge of the movement.
I am wondering if the dial is somehow attached by a snap-on / pressure fit and is levered off similar to the crystal bezel?
Brgds
Michael O
Posts: 18 | Location: Kelowna, British Columbia. | Registered: November 04, 2007
IHC Member 1555
posted June 26, 2018 06:54
I think you first impressions are correct re; snap-on type. I am pretty sure that these dials are the interference fit type, you must be very carefully prying it up.
posted June 26, 2018 11:46
Thanks for your words of advice. I have never encountered one of these types before.
The dial is an interference fit and it came off with some gentle pressure.
Best regards.
IHC Member 1555
posted June 26, 2018 17:30
Your WelcomeSmile
