I have a TR Pocket Watch which does not run. The main reason I beleive to be the incorrectly sized Balance staff (although I cannot be sure whether other items in the assembly are correct) as gentle oscillation of the Fork promotes movement in the Escape Wheel indicating there is power reaching that far in the train when wound up.
I am not sure either, whether the Balance Cock should be numbered the same as the movement serial as is the case with Walthams, if so the Balance Cock is not original. There also seems to be a kink in the Hairspring.
As a minimum I think that I need to get the staff replaced with a correct one, possibly a relacement Hairspring and the jury is still out on the roller depending on its originality or not.
Any comments on my diagnosis would be appreciated as my experience is very little but growing all the time.
The Watch
Thanks for taking the time to look
Posts: 99 | Location: Surrey in the United Kingdom | Registered: June 01, 2011
Also a question for Thomas Russell knowledgable out there I see the minute hand is not blued in the centre and that appears hollow, would this indicate a missing sweep second hand ? or is this merely a "feature"...
Hello Gareth,I have a Thomas Russell and son movement that looks similar to yours.From the dial that's on it and the hollow center post,it probably had a center second hand.The balance assembly is perfect.The 4th wheel pinion,or the second hand post is broken.It has a broken pivot on the pallet lever.Also the cannon pinion has a couple of teeth missing.Sounds worse than it really is.If it's the same movement you could use your lever, and cannon pinion and have a running watch with all the same numbers.I'm going to be away until the 28th.Check with me then.You can email me at taloneka@windstream.net.Regards.Norm By the way,you can have the movement if you pay shipping.
Posts: 484 | Location: Georgia in the United States | Registered: August 04, 2010
I suspect that your movement was made by H. Williamson of Coventry, England. If so, the name will be found under the dial.
If there is any rust on the hairspring then the balance w/spring should be replaced as a unit (if you can find a junk movement with a good balance unit).
Posts: 2052 | Location: East Lansing, Michigan USA | Registered: November 24, 2002
