K&D M/S Winder model ? "Click" to Login or Register
I've recently acquired a winder which appears similar to the model 128 but has only one winding shaft with a permanent handle. Two of the "barrels" that came with it, naturally one is the size I need the most, are several thousandths smaller in diameter than the winding shaft. I might be able to grip them in a 3-jaw chuck and bore the center out a bit to allow their use. Any thoughts would be a big help. Thanks Michael, a new member.
K&d m/s winder model?
Posts: 1 | Location: Washington, Iowa in the USA | Registered: February 12, 2010
Site Moderator
Picture of Tom Brown
Michael
Not too sure what to tell you about the problem, I have what appears to be the same winder as you. The winding handle can come off by loosing the set screw on the winder.
Wish I could be of more help, mine came with 8 different size winders & they all fit fine over the shaft. Do they all look like the same brand, I know Marshall ones won't fit on a K&D.
Also welcome to the club.
