Was "Santa-Fe" a real Watch Company?
May 23, 2005, 14:34
Frank KusumotoWas "Santa-Fe" a real Watch Company?
This advertisement from Collier's, 1920, says order this watch from the "Santa Fe Watch Co." located in Kansas. Was this a real watch co. like Ball?
May 23, 2005, 16:50
John ArrowoodVery interesting! Apparently Santa Fe like Burlington offered to engrave the owner's signature or other decoration on the case back. Was there any connection between the two companies?
May 23, 2005, 17:13
Thanks for sharing that great ad Frank,
As they allude to in the ad, both Santa-Fe and Burlington were thinly veiled Illinois watches sold direct to the public through mail-order advertising.
So John, the "connection" was indeed the true manufacturer of the watches.
May 23, 2005, 17:25
Tony DukesFrank,
Keep those ads coming here on the 185 site. Many thanks for sharing.
May 23, 2005, 18:53
Edward L. Parsons, Jr.Cool ad Frank, thanks for sharing.
The "mile a minute" clip alluded to in the ad was fast indeed for the steam locomotives in use in 1920 and would have been a typical top speed of a passenger train highballing down a main line. In that year the
average speed (including stops) for passenger trains in the U.S. was about 22 MPH and the average for freight trains was a little over 10 MPH.
May 23, 2005, 20:10
Frank KusumotoTony,
I could post old ads all day, unfortunately not at a mile a minute! I'll try to keep them coming though.
I wonder, what really makes the dividing line between a big "Private Label" and a "Company", like comparing Santa Fe and Burlington to Ball.
Frank "407" Kusumoto
May 23, 2005, 20:58
Jerry TreimanTo me, the main difference between Ball and other private labels is that Ball adjusted the movements to their own standards after they were received from the true manufacturer. Other than that, they all ordered custom finished movements from one or more manufacturers, often with a custom plate pattern.
May 24, 2005, 10:11
D. Scott McKinleyIt seems that Ball, Burlington, and Santa Fe were the big three private lable watch companies.
May 24, 2005, 11:35
Jerry FreedmanDid not the late Bill Meggers have some questions as to the position adjustments to the Santa Fe Specials? Were they 3 position watches? If so, how are they being used in railroad service?
May 24, 2005, 13:49
Russ SnyderIn response to Jerry Freedman's question, I know of only two Grades of Illinois watches sold under the Private Label "Santa Fe Watch Co." that qualified as RRG:
(A) 16S-21J Model 9 Grade "A. Lincoln" -- including two production runs totaling 200 watches maximum:
3,457,001 - 3,457,150
3,457,201 - 3,457,250
(B) 16S-21J Model 9 Grade "561" -- including one production run of as many as 1,000 watches:
5,356,001 - 5,357,000
All other watches made with the Santa Fe marking were adjusted 3 positions, except for the smaller ladies watches in "0" size (Grade 37) and "6/0" size (Grade 903)
Russ
May 24, 2005, 15:36
Tom McIntyreIt is interesting that the ad does not say railroad approved or have any other language regarding railroad standards. It just says this particular engineer carries one.
It was true then, as today, that you have to read the words that are missing from an ad to know what it is actually saying.
Railroad watch had no meaning except that it was the kind of watch that railroaders used. It was not that different from the usage today on eBay.
May 25, 2005, 13:56
Russ SnyderI do have photos of other "A. Lincoln" Grade movements with P.L. markings:
"RAILROAD GRADE -- S. AALTO"
"TASCO"
"D & R.G. SPECIAL"
"COMMODORE PERRY -- O. COHEN"
Interestingly, however, I looked at Meggers book (p. 279, #6) and discovered that Bill marked this as a "RRG" Model 8 Grade "606" T3PI. However, his listings on p. 254 have a reference to the photo on p. 279, but don't designate the watch as RRG.
Looking at the serial number listings Bill has on p. 407 for the run that included the watch pictured on p. 279, he shows it as a run of pendant-set Model 6 movements from 3,916,601 - 3,917,000. I would assume that the RRG designation with the photo is probably a typo, since there are no other Grade 606 movements listed as RRG. Likewise, the Model 8 designation may be incorrect, since I can find no Grade 606 production runs which are lever set.
Russ
May 25, 2005, 17:29
Russ SnyderFor the Private Label versions I listed in my previous message, here are their patterns:
"RAILROAD GRADE -- S. AALTO" = 2-tone checkerboard
"TASCO" = same as 17J Bunn -- Sunburst (3rd) pattern, but with a gold border
"D & R.G. SPECIAL" = nickel only with center similar to fish-scale Bunn, and outer ring plain nickel -- the dividing line is a circle that passes thrugh the center of the winding wheel.
"COMMODORE PERRY -- O. COHEN" = damaskeening pattern identical to A. Lincoln. -- bright-striped pattern, nickel only, the last one is also marked "ERIE, PA."
Russ
Here is a photo of the "Perry" movement.
May 25, 2005, 17:30
Russ SnyderAnd here's the "D & RG Speical" photo.
