Waltham Vanguard Model 1892 - 19 Jewel - Hunter
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/9593984877
May 19, 2013, 14:33
Jon Hart
Just wanted to pass along some information on the Hunter 1892 Waltham Vanguard movement - 19 jewels
Apparently Waltham only made ~ 800. There were 2 Variations. The first occurs in a run from - 11033501-11033700. The rest occur in the 11500310-14057300 range. Both variations came with 3 barrel bridge screws and the case screw position between the winding wheels. This one also has the serial number at the bottom of the barrel bridge.
This specific one was born in the beginning of the second run and was found in a trashed out base metal OF case Eek . The Fat book gives a one Star rating and price range of roughly 350-750
May 19, 2013, 15:17
Bila Wirriganwalters
A great pick-up Jon, a diamond in the rough.
Bila
May 19, 2013, 18:45
Jon Hart
Thanks Bila... Smile
The Model 1892 is an interesting creature with just the six or so different winding wheel patterns by themselves.
May 19, 2013, 19:23
Edward L. Parsons, Jr.
Cool watch Jon, and though it seems strange for Waltham's highest grade M92, the blank winding wheels are correct.
May 19, 2013, 20:20
Walter B. Rees
What is the "fat book" you refer to?
May 19, 2013, 20:26
Jon Hart
Walter,
"The Complete Price Guide to Watches"
Cooksey Shugart
May 20, 2013, 02:59
Evan Patton
You know Jon I've got a nice silver case that movement would look swell in.
May 20, 2013, 21:23
Tom Dunn
I could probably come up with some cash as well
Tom Dunn...
TIME MACHINE
www.myrailroadwatch.com
May 20, 2013, 21:43
Mike LaForest
I can always use another! Smile Here is an early serial number example.
May 20, 2013, 22:51
Jon Hart
Mr Mike...
I do have a question for you... There was also a Pendant Set 21j 1892 Crescent with this one. What is the history on the pendant set versions on the 21j?
New to me...
May 21, 2013, 21:39
Mike LaForest
From what I can see, there are just as many PS watches manufactured as there are lever set ones. When Waltham came out with their first 1892 grade it was a HC, lever set model (17J), and it was immediately followed by a PS, open face model. Throughout the history of this Model, there seems to be equal numbers of PS and LS watches produced. I presume the LS models were primarily for the RR workers where lever sets were required.
According to Walthams records, the first Crescent Street run was a PS model, (Serial # 7007001) but there were LS models mixed in the first run, as well. I have found that Waltham's own records are just a mess. There are numerous exceptions in their own production records especially with regard to jewel count, and PS vs LS movements. I am attaching a couple pictures of a first run Crescent Street - which is supposed to be a PS movement according to their records. It's lever set!
May 21, 2013, 21:40
Mike LaForest
....and now the dial. Did I answer your question? Note the lever.
May 21, 2013, 22:04
Jon, I posed this question back in March on the '21 jewel Crescent Street' as I have not seen as many pendant sets as lever sets, Bob (aka Robert McClelland)responded saying that the ratio of lever to pendant set is somewhere around 4.5 to 1.
Bila
May 22, 2013, 14:41
Mike LaForest
As accurate as Waltham's records are, I just added up the first 28,000 Mdl 1892's of all grades combined. . There were 14,000 PS movements and 14,100 LS movements. This would take us through the first 3 years of production.
I then checked Waltham's records for the first 10 years of 1892 production just for Crescent Streets. Although there were several large runs of Crescent Streets where the set was not described, there were 200 PS movements and 11,100 LS movements. This was an eye opener for me. The Crescent Street, pictured below, is from the first run of 1000, PS, Crescent Streets.
May 22, 2013, 15:53
Mike LaForest
Here is the dial for the above pictured Cres. Street. I believe the dial is period, but not sure about the hands. Thoughts?
May 22, 2013, 18:34
Jon Hart
Very interesting information on the first three years (28,000 combined 1892 grades). 90% of the 1892s out there seem to be lever set. Therefore, I would be in the same camp with Bila, w/o the information that Mike produced.
Also, really like the center stamped serial # on the early 1892. Bold and beautiful - Smile
June 13, 2013, 05:01
Peter Nicholson
This is a '92 Crescent Street from my collection. It is also from the first run and is lever set. It is also marked '5 positions' which is unusual for such an early movement.
Peter Nicholson
This is the dial.
June 13, 2013, 05:12
Peter Nicholson
Sorry, wrong pictures! These are the correct ones.
June 13, 2013, 05:13
Peter Nicholson
And the dial.
