September 07, 2013, 23:05
Ken HabeebHamilton 910 casing
Speaking of that Ham 910, the database has this note at the top: "Only Sold Already Cased by Hamilton."
But this watch is in a Montauk 20-yr swing-out case w/o any other case marks. Does this mostly likely mean A) it was recased at some point by a jeweler or watchmaker into an unused swing-out case? or B) there are exceptions to the Database "rule."
I see that others on eBay are in Hamilton-marked cases, so I favor the former, however odd it may be to consider recasing into a swing-out, which Hamilton did use, if not often.
Whatever the case, that watch is a good runner.
kh
September 07, 2013, 23:07
Ken HabeebApologies. Here is the info given:
Grade: 910
Movement Serial Number: 1790540
Estimated Production Year: 1914
Run Quantity: 25000
Jewels: 17j
Movement Finish: Nickel
Model: 1
Movement Setting: Pendant
Plate: 3/4 Plate
Adjusted: Yes
Adjusted to Positions: Unknown
Railroad Grade: No
Notes: Pillar Plate Diameter: 1.630"
September 09, 2013, 17:11
Ken HabeebDo any members here have a Hamilton 910 that is in a case w/o extra case marks, but not in a Hamilton case?
