October 14, 2011, 19:09
Claude GriffithFor the Elgin experts- what is odd about this watch??
I thought I would toss this out there to see if the Elgin experts can spot what is wrong?
October 14, 2011, 20:02
Jim BielefeldtWhile I love Elgins, I am far from and expert. Let me take a stab. Its marked Adjusted to 3 Positions instead of 4.
October 14, 2011, 20:07
Steven FordClaude,
I dont know if it is wrong or not, but mine from the same run, 17015381, says adjusted 4 positions.
The elgin data base says they are all adjusted 4 positions.
Nice watch! Looks great to me!
Steve
Hey Jim you beat me to it!You posted while I was typing.
October 14, 2011, 20:08
Ronny ManisIs the balance cock correct?
October 14, 2011, 20:18
Claude GriffithJim and Steven are both correct, Elgin made 5 runs of 1000 for the grade 342, the first run was only marked Adjusted and there was a few years gap before the later runs but runs 2-5 should be marked Adjusted 4 Positions. The balance cock is correct, run 1 had some design in the area between the micro-adjuster and the jewel but runs 2-5 look like this one.
I have one of each run and this is the first one I have seen adjusted 3 positions. I guess it was friday and the person figured 3 is enough for this one, Charlie's bar is waiting. I was the only bidder, nice watch with a nice Empress coin-edged case.
October 14, 2011, 20:21
David AbbeAs part of the first 1,000 made, mebbe they did 3 adj furst.
October 14, 2011, 20:28
Claude GriffithThat might be the case if it was the first run but this watch is 925 of 1000 of the 2nd run. If it was early the 2nd run I would think that would be also possible but since this one is very late in the run I think the person putting the marking on was running late for the bar.
This is an example of the first run.
October 24, 2011, 23:38
Patrick WallinWhatever. You go to Charlie's bar and I'll give you 100.00 for the watch.
October 27, 2011, 16:50
Claude GriffithI guess I was wrong on my other 2nd run it is also marked adjusted 3 positions. It appears that the first run was marked adjusted, run 2 marked adjusted 3 positions, and runs 3-5 marked adjusted 4 positions.
I had to pull them out and double check the markings and saw my memory is slipping a bit.
