September 10, 2013, 12:31
Jon HartAlright masters of the Universe
Clue #1
Picture and size of movement in mm
Care to take a stab at brand and size?
And how you reached your conclusion
Some good clues within
September 10, 2013, 12:48
Peter KaszubskiI will take the 5th on this one
since Im the master of the universe
September 10, 2013, 12:56
Francesco Marco MaraschinIll go with it being a Hamilton (just a guess).
September 10, 2013, 12:59
William D. White16 size Elgin? I haven't had a watch apart for a few years but it just looks familiar. Also hunting and pendant set.
He-Man
September 10, 2013, 13:12
Dave TurnerI'm with William.
September 10, 2013, 13:18
Douglas D. WeaverI agree that it is 16-size Elgin. Plus, it's a hunter.
September 10, 2013, 13:39
Gerald ZimmermannHunter is ok
41.88 mm is closer to 18.5 ligne + perlage
--> swiss ?
Gerald
September 10, 2013, 14:01
Claude GriffithI will hang with Mr. White with one slight difference rather than Elgin I think it is Elgin Export. Elgin made a few grades that they exported mostly to the UK, when you put them in a normal US 16 size they tend to swim a bit. So on my two (hunter and open face) 16s export models that only 300 were made of each and I have to use the typical UK cases rather than the US 16s cases. I will toss that one out there just for yuks.
September 10, 2013, 14:20
Gerald Zimmermann14s Elgins ?
Gerald
September 10, 2013, 15:02
Claude Griffithwell not 14s but maybe those oddball 12s Lord Elgins that they made, which the 19j was the most common. My earlier guess is wrong since those export models were 17j and would not have a gold center wheel which this one appears to have. The these 12s Lord Elgins came only in open face, in a special case, and it seems there was also a GM Wheeler grade that is the same general shape and size but they won't fit a standard 12s case because they are larger. All three are in the 45X grade range.
September 10, 2013, 18:08
Eric UnseltRockford.
September 10, 2013, 20:46
Jon HartClue #2
A serial #
September 10, 2013, 20:48
Jon HartClue 3
Dial side up
September 10, 2013, 21:11
Claude Griffithwell the serial number tips it off for an Elgin grade 152 a 15j version of the 155/154/153 3/4 plate grade hunter movement.
September 11, 2013, 00:46
Bob MurrayAnd a broad arrow. Purchased by the UK Ministry of Defence?
Bob
September 11, 2013, 09:07
Jon HartBob - I wondering the same thing
