Need grade number on Hampden "Click" to Login or Register
Picture of Eugene Buffard
I checked the online data base for my A K Jobe Hampden. And can't find any info on it.
Thank You in advance.
# 1077826
Here's the dial
could that be a 3 not a 0?
If so, I get the following
Grade: New Railway
Manufacturer:Hampden
Manufacturer Location: Springfield, Massachesetts and Canton, Ohio
Movement Serial Number:1377826
Grade: New Railway
Model: 5
Estimated Production Year: 1900
Jewels:23j
Movement Configuration:Openface
Movement Finish:Nickel
Movement Setting:Lever
Plate:Bridge Plate
Regulator:Patent
Adjusted:Yes
Adjusted # of Positions:0
Adjusted to Temperature: Yes
Railroad Grade: Yes
Posts: 507 | Location: West Newton, Massachusetts USA | Registered: September 10, 2006
Picture of Peter Kaszubski
size 18,grade 67,model 3,17 jewels movement
total production 5575
first serial # 1077701 last serial # 107800
production in this run 300
total runs 10
total of variations in grade 2
and was made in 1896
Administrative Assistant
Picture of Dr. Debbie Irvine
See this response in the other topic requesting grade information…
The movement is marked AK Jobe. Jackson Tenn. Water Valley Miss. 17 Jewel Special Adjusted 1077826 it is a Hampden
posted October 08, 2015 20:04
Just a little info on that Hampden Gene, Grade 67 model 3, production year around 1898. Total production just under 6,000, there were 2 variations in finish, your variation made up a total of approximately 4,000 of the 6,000.
Cheers,
Bila
Posts: 5859 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
