American pw clone?
July 22, 2008, 06:04
Fabrizio Di ClaudioAmerican pw clone?
Hi, i buyed this 18s pocket watch, but i not know nothing about it. Im not sure is an American pocket watch, possibile swiss or english clone?
Thank you!
( Broken gear..)
July 22, 2008, 11:40
Donald TrumbleFabrizio,
My opinion is the overall watch has a "swiss fake" look to it. The overstated markings raise suspicions but the apparently non functioning regulator is a big strike against it.
I can't say for certain but I'm not sure that gear device is really damaged. To my eyes it looks like someone intended to cut it that way. Others may know for sure.
Don
July 22, 2008, 13:39
David AbbeFabrizio, that is indeed a swiss "counterfeit" US-style watch movement. The "broken gear" is a cut out part of the old wheel made when someone was attempting to repair it by soldering in a new piece of metal that they can hand-make new teeth for the winding gear. The case is worth 3 times the watch. I picture a swiss counterfeit that I bought for the case for your comparison.
July 22, 2008, 17:56
Fabrizio Di ClaudioMany many thanks Donald and David!!
Now i have "fake" american pocket watch in my collection, eheh no problem i like it.
Movement is working, problem is only damaged gear, and is not compatible with elgin and waltham gear.
I will try solder it and to reconstruct the teeth.. not easy :-(
Fabrizio
July 22, 2008, 19:57
David AbbeFabrizio, I have two SDwiss Counterfeit "parts" movements that I will give you "free" if you will pay for the postage! Just advise your address and how I should send them. The smaller winding gear measures about 8.86 mm outside diameter and the larger gear measures about 11.6 mm outside diameter.
July 22, 2008, 20:00
David AbbeThey are quite different on the Balance wheel side, but at least you get a lot of swiss conterfeit movement screws.
July 24, 2008, 08:17
Marty BellI applaud your attempt,my friend! Everytime I try something new in repair it takes me more than one try-usually more than two,too!
Don't be discouraged;show us your progress! Your pictures are great and we all learn from them-if you can't get that gear to function as it is, I'm sure with more work you will.
Marty
July 24, 2008, 12:01
David AbbeFabrizio, I can send you the wheel. It should work for you because the thickness is 0.69mm. You can make that thickness corect for your watch very easily, and the 3.73 mm inside diameter and 11.45 outside diameter can be fitted to your watch! I would send you the complete watch movement and you could chose the parts to use to make yours work best!.
July 24, 2008, 17:55
Fabrizio Di ClaudioCOOL!!! Thank you very much David!!
My email is programmer@altern.org contact me and i send you address and money.
Today i restored movement, damaged gear work but sometime winding is locked and non free.. i prefer your gear :-)
Now movement is clean and oiled.
Damaged mainspring, i fixed it..
The case.
July 24, 2008, 17:59
Fabrizio Di Claudioquote:
Marty
Thank you Marty!!
July 24, 2008, 18:02
This is great!
Three guys working together from California, New York and Italy is what the IHC185 is all about!
July 24, 2008, 22:43
David AbbeAfter the beautiful workbench he shows us, and now we look at what Fabrizio is doing to restore that watch, we should "nickname" him "Fabrizio Di Claudio-Magnifico!
July 24, 2008, 22:48
Donald TrumbleYou're right David,
Fabrizio DiClaudio is a Fabulous Craftsman, he earned the title!
Don
July 25, 2008, 00:57
Sheila GilbertFabrizio,
Your work is Fantastic!
I also have a few "fakes" that I purchased on purpose too. I like all of them, even the fakes.
Your movement sure turned out gorgeous, it looks almost brand new, and I admire the hard work you did on the needed parts. You have a great talent for watches, and thank you so much for showing us your work.
Sheila
July 28, 2008, 23:08
Darren SandersThe repair looks great. i like your diligence. it is work just like this that helped bring about the name "watchmaker". How did you "solder" the piece into the gear?
I think that the repaired gear is "locking", from what i can see, because in the place of the 2 cut teeth there should be about 4 or 5. Of course i bet just cutting 1 of those teeth was not to easy.
Keep up the good work. If you get time look at the pics of the bridge i am making in the post "elgin sweep sec". Hey, if you dont have the part make it.
July 29, 2008, 08:01
Fabrizio Di ClaudioThanks to all for the compliments. I am happy
Many Thanks to Dave for gear and movements shipped to my house in Italy!!
July 29, 2008, 08:19
Posted July 28, 2008 23:08
Hi, im electronic repair of alarms systems and security cam. ( im not a watchmaker, i like repair pw of my collection, is my hobby ), i used normal solderig for circuit and chips. Is a particular solder, i read TIN/LEAD 33 % the name of product is Super Solder the best flux corf.
Fabrizio
August 15, 2008, 20:32
Sheila GilbertWOW!!!!!
Fantastic!
It's so clean and beautiful! Great Job.
Sheila
August 16, 2008, 00:31
David AbbeFabrizio, with the skills and perfection you applied to this, you made a better watch than the original!
Wonderful job, and I am proud to have been able to help your success with "putting the original watchmaker to shame".
August 16, 2008, 13:33
What a wonderful story this is!
Fabrizio, you demonstrate an outstanding level of dedication and craftsmanship that few have today. Without people like you many of these watches would be nothing more than spare parts.
Beautiful workmanship and outstanding pictures, your posts are an encouragement to all of us!
August 18, 2008, 17:59
Fabrizio Di ClaudioThank you Sheila, David and The President! I'm happy read your compliments!
