Pocket Watch Hand Pushers Needed "Click" to Login or Register
Picture of Ken Knight
Where can I look for a set of hand pushers for pocket watch hands? I see pushers from current suppliers, i.e. CasKer; would I do better buying from them, or are there pushers specifically for pocket watch hands? Let's not forget the size found in key wind watches.
Posts: 285 | Location: Springfield, Ohio in the USA | Registered: June 06, 2008
Ken, The "book" says to put the hands on using a staking set to properly support the other end of the Main wheel arbor so that you do not damage the main wheel pivot bearings or jewels. This has a lot of merit, but takes more time to set up.
That said, there is a hand setting tool that looks sort of like the old comic book advertised "blackhead remover" that you can (and I sometimes do) use to set the hands after they are positioned on the canon pinion (minute) or hour wheel sleeve. Be careful, though.
The few times I have to set the minute hand on a Key wind watch, I use the hand setting key as a press, as the diameter across the square hole is usually too large for anything else conveniently close at the moment.
