October 15, 2019, 19:13
Harry J. Hyaduck Sr.18s Hampden Mainspring Barrel Question
I opened up a RRG Hampden 15j 1884 Mermod Jaccard & co. Model 3 lever set stem wind with gold jewel settings the other day and saw this mainspring barrel. I have never seen one like it before. Is there something I should know before I remove it? I am not going to mess with it unless I need to in the future but I don't know what that star wheel is for on the top of the barrel.
Harry
October 15, 2019, 19:56
Kevin HoffmanHi Harry , that is a spring barrel with "stop works " on it , It is used to keep the mainspring at its optimum pressure , by not allowing it to run all the way down . I am having trouble explaining it , maybe some one else could do better. This link will help
https://ihc185.infopop.cc/eve/...741080133#1741080133October 15, 2019, 21:05
Harry J. Hyaduck Sr.Thank you Kevin and thanks for the link. David explained it very well as did you. This one is running so I am not going to mess with it but it looks complete to me but I guess you would have to take the barrel apart to see. It looks to be a high quality 15j movement.
Thanks again Kevin,
Harry
October 15, 2019, 21:50
John ScottPart of the stop work is missing so it has no effect. That being so, the barrel can be treated like any other.
October 15, 2019, 21:52
Harry J. Hyaduck Sr.Thank you John. I will have to try and find a picture so I can see what it used to look like before whatever part is missing was removed.
Harry
October 15, 2019, 21:56
Harry J. Hyaduck Sr.I found a picture now that I know what it is called and I see the part that is missing. I have those parts somewhere now I know where it goes as long as they fit.
Thanks for all the help!
Harry
