Fahys case ?
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/7271027402
August 23, 2006, 19:38
James A. Daigle
Fahys case ?
Fahys Montauk 16s marked RR serial #503110. About what year and what watch copany would be correct for this case? Thankyou, Jim.
James Daigle
August 24, 2006, 18:15
John Johnston
James,
Is it possible to see a photo of the case please?
John
August 25, 2006, 18:52
James A. Daigle
Sorry camera is "out of service" at this time. Case has engine turned back with small floral design, dust free crown with french bow. This is a fairly plain looking case. Thankyou for your post, Jim.
James Daigle
August 25, 2006, 19:06
I have some Fahys cases from the 1920s with slightly lower numbers but they are not the Montauk model. It is possible they used a different numbering sequence for each model. Some case companies used different sequences for white versus yellow and such so time frame can be difficult to determine.
About what came in your case, the Montauk was generally considered to be a generic or jeweler item which means any make could in theory have come in it. The case-screw marks may actually be the only valid clue. For that reason their exact positions or as John suggested a picture would be helpful.
August 26, 2006, 18:32
James A. Daigle
17j Elgin with serial#16004713 came in this case. Just thought it odd that it was marked RR in the case back. Maybe someone was proud of the Elgin and put it in railroad case? Thankyou, Jim.
James Daigle
August 26, 2006, 18:53
I think you're right Jim,
From the number that movement dates to 1911 production...
http://elginwatches.org/cgi-bin/elgin_sn?sn=16004713&action=search
It is fair to say your watch was probably cased at the selling retail jeweler. If it is a high pendant case and there are no other case-screw marks it could be an original combination.
Do show us a picture in this topic when you can.
August 27, 2006, 17:07
James A. Daigle
Thankyou, your post is most helpfull.
Jim
James Daigle
