HELP ID RYRIE BROS PRIVATE LABEL MOVEMENT LONGINES? WITTNAUER?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
The dial says Ryrie Bros which was a precursor to Henry Birks Jewelers (now Maison Birks) It is marked Swiss & 15 jewels The dial side has HERALD & 670 around the outside edge and WITTNAUER inside of that. The watchmaker had it in a container marked LONGINES I can't find another movement like it... Roddy JB ![]() | ||
pic 2 Roddy JB ![]() | |||
pic 3 Roddy JB ![]() | |||
| IHC Member 1555 |
What's it diameter Roddy, or how many lignes? | |||
| IHC Member 1555 |
The maker of that movement Roddy is "Revue" (Thommen) from around 1890's to early 1900's. I take it, that it is around a 16 Size American, if you give me the size I will be able to give you the caliber? | |||
Hi Bila, I never got a notification you had replied... The mvt measures about 36.4mm The dial measures about 40.5mm I found something similar on Dr Ranftt's BidFun site --- a Revue 19'''H5.6 Strange, there were 100's of tins and what was marked on the outside is what was inside Ergo, I figured this had to be a Longines possibly but there you go... Rod Roddy JB | |||
| IHC Member 1555 |
It is a bit of a crossover/transitional between the Caliber's 19"-H5.6 (your's has the same back-plate as this) & the plain Revue 19" Caliber (your's has the same dial-plate setting mechanism as this), but for all intensive purposes the 1st above Roddy As for the Watchmaker saying it was a Longines on the tin Roddy, who nows??? A lot of people think alot of the Wittnauer's were made by Longines which is an incorrect assumption on their part | |||
Cheers again Bila, I guess getting one wrong out of about4-500 isn’t too bad… Roddy Roddy JB | |||
| IHC Member 1555 |
He did a Good-Job | |||
