Operation of Hamilton 1941 992B "Click" to Login or Register
I have my grandfather's 992B he wore while engineer on the B&O's Capitol Limited and Ambassador trains up till 1946. It winds fine but I cannot get the stem to pull out. I am assuming the stem does pull out to set the time, right?
Posts: 1 | Location: White Hall, Maryland in the USA | Registered: April 09, 2008
The watch is lever set. Do not continue to pull out on the crown, it is for winding only. To set the watch you will have to unscrew the front cover of the watch. A lever will be obverved sticking out slightly in the right quadrant of the dial. Carefully slide out the lever. You should then be able to adjust the time by turning the crown. Then slide the lever back in, screw back on the front cover and you should be good to go.
Posts: 292 | Location: Vancouver, Washington, USA | Registered: May 19, 2005
This military 992B has the same lever. You just unscrew the front Crystal Bezel, pull out the lever and then you can set time using the winding crown. Be sure to push the lever back in before trying to reassemble the front Crystal Bezel.
GREAT RESPONSES, FOLLOW THOSE INSTRUCTIONS CAREFULLY!!!
Charles,
Michael and David just saved your grandfather's watch my friend! After you say a very big thank-you to both of them we then we invite you to go to the top of this page in the Join and Support Internet Horology Club 185 area and become a full IHC185 Supporting Member Smile you'll be glad you did.
By the way, your dial and hands are entirely correct, they were used only for a short time during WWII and therefore are unusual. Congratulations on having a great family heirloom!
Here is another 992B in an early "Case 11" like yours...
