bunn special sixty hour ?
April 03, 2003, 03:39
Eric Kroonbunn special sixty hour ?
I ran across two of these watches in a pawn shop today! one says sixty hour over the words bunn special, the other says motor barrel 60 over the words twenty one jewels! My question is is one more desireable then the other? i can only afford one,
thanx! oh, the cases and dials are in the same shape give or take and the price is the same on both.
Eric Kroon
NAWCC Member 151367
Proud IHC Member 183
April 03, 2003, 07:46
Terry HillOf course, buy em both....
but the motorbarrel 60 is the lower production one... it is called a TYPE I
April 03, 2003, 14:32
Lindell V. RiddleEric,
Depending on price I very much agree with Terry, they are both worthwhile. THE TYPE I is a fairly low production at only about 9,100 made.
The other with "Sixty Hour" above "Bunn Special" on the train bridge sounds like a TYPE III which is more common at 86,000 produced. The TYPE III also has no "60" after the words "Motor Barrel" by the crown wheel.
All things being equal the TYPE I is indeed the more desirable. Serial numbers would always help to narrow it down in a situation like this. If you can post the serial numbers we can give you more conclusive information.
Go get 'em Eric!
April 03, 2003, 20:49
Ed UeberallI suppose just for the sake of completeness (is that a real word?) we should mention the Type II, which was a transitional marking between the Type I (Motor Barrel 60) and the type III (Sixty Hour, on the train bridge). The Type II had
both markings, the
Motor Barrel 60 and the
Sixty Hour. Here is a brief chart of the production quantities for each of the types in 21 and 23 jewels, as compiled by Bill Meggers:
.....................21 Jewels.........23 Jewels
..........Type I.......9,100.............1,350
..........Type II......7,000...............500
.........Type III....86,000............12,000
Ed Ueberall
NAWCC #49688
IHC #34
http://members.aol.com/stdwatch/April 03, 2003, 22:34
Terry Hilljust to piggyback on some other comments and info....
There have been many 'discoveries' since the publication of Megger's book. There have been examples seen that change these numbers slightly, but maybe not enough to alter the sacarity rating.... point is numbers subject to change... and information is being gathered all the time for research of these and other items...
Not sure of exact timeframe of disclosure of the modified numbers, but it is being worked on...
but back to watches at pawn shop.....
buy one, put one back for later.... lay it away..don't tell us were it is ....
April 03, 2003, 22:49
Eric KroonAlready done!
Eric Kroon
NAWCC Member 151367
April 03, 2003, 23:04
Terry Hillcongrats.... tell more about em...
April 03, 2003, 23:59
Good for you! We're all delighted to see the
plural in your post. Ed, Terry and I along with many others will be interested in the serial numbers and pictures.
These are great watches and welcome additions to any collection.
Looking Forward,
April 04, 2003, 00:45
Eric KroonWhat happened is i worked a deal on both watches and he wouldnt let me take one home so there both on layaway. it will be a month or so until i get them, but will post the numbers when i do, sorry fellas im only thirty something and still working to keep the wolf from the door
one day i will be retired and have all the money in the world like you guys
ERIC
Eric Kroon
NAWCC Member 151367
April 04, 2003, 00:54
Lindell V. RiddleWe're not rich guys Eric we just love these watches.
All of us will be looking forward to seeing what you scored. It would have been interesting to do all the research so you'd be sure of what you have coming.
Now you REALLY DO look forward to next month!
