Elgin grade 349 marked Father Time adjusted 5 positions
April 06, 2011, 23:23
Claude GriffithElgin grade 349 marked Father Time adjusted 5 positions
There was an Elgin 349 that made more than a few relisting passes on ebay and the seller finally dropped the price $100 to a more reasonable amount and I was the only bidder on it. I had just picked up a grade 349 that was a bit unusual because it had 5 positions marked on it as somewhat of an afterthought. This 349 is marked Father Time and below that 5 positions then below that Elgin, Ill USA. I changed the SS metal dial to a correct DS dial with red 5 min markers. I personally have not seen too many grade 349's marked Father Time. Does anyone else out there have a FT grade 349?
April 06, 2011, 23:35
Bill MandersClaude,
Show us a pic. of this one, if you would please, I don't think I have ever seen one, but had heard of them.
Bill
April 07, 2011, 11:33
Jerry KingYes, the 349's were sometimes marked Father Time....but it is more rare than '349'....
Claude a photo or two would be nice and well as the serial number....
Great find, Claude, it just takes a little patience....
Opps, there they are....Very nice Claude, I can't quite make out the s/n...?I found it....
April 07, 2011, 11:45
Claude Griffith
Jerry I was uploading the pictures as you were typing and you beat me to the finish. I was a bit surprised people let it slide by since it did at least 3-4 relistings on ebay. The seller dropped the price to $240 some and I was the only bidder. It was running a slow and it appears I got a bit happy with the regulator so I will have to slow it down a bit but it appears to run/set well and the movement is clean without any major scrapes, scratches and the case does not have any extra screw marks.
I see that I missed uploading the case back picture.
April 07, 2011, 12:00
Jerry KingYes, sometimes one can find examples like this one, but it does take patience....
This one came from the 21st run of the 349's and it is difficult to determine exactly how Elgin did their naming of grades because there were 4-5 runs that did not have names associated with them and I was wondering if maybe they were the runs that were not designated 349....but your watch dosen't fall in one of those runs....
I know a few of the 349 runs were originally designated to be grade 252 but were later re-designated 349....
Well, at any rate you have a nice one for sure....
Oh, BTW, I think the watch is original configuration coming from the factory minus the dial you had to change but the one you put on is an appropriate dial....
April 07, 2011, 16:24
David AbbeI am listing this Gr252 FT on eBay today. As an 1899 production it only says "Adjusted".
April 07, 2011, 19:38
Larry BuchanClaude:
Here is a photo of my No. 349, Father Time, it has a Canadian private-label dial.
April 07, 2011, 21:30
Claude GriffithLarry yours looks to be a bit earlier than mine and you can tell there was enough room without much change to get the 5 Positions just below Father Time.
April 08, 2011, 12:16
Larry BuchanClaude According to the Elgin collectors site database my watch Serial No. 13398779 was manufactured in 1907. And yours Serial No 13885609 was manufactured the year after in 1908 requirements for marking "5 Positions" must have changed around that time.
April 08, 2011, 21:31
Mike LaForestThanks for the education fellows. I did not know there were 349's stamped FT! Claude, you devil! Nice pickup!
April 08, 2011, 21:57
Claude GriffithLarry sometimes it is hit or miss during that time frame, my 341 is run 1 and it has 5 positions marked on it but I saw a 341 from run 2 and it wasn't marked so sometimes I think in that time frame it was hit or miss. Mike that is why I like it when people post pictures there are many movements or grade variations that I have not seen, when people post these it is really helpful. If Elgin made 10-20% of the 349's then that means there were probably 5,000 or less produced but as Jerry mentioned there are no clear numbers on the FT349 markings.
April 08, 2011, 22:09
Bill MandersSure a great looking movement Claude, thanks for posting, now it will be on my list.
Bill
