Illinois conversion dial?????
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/5721032903
April 24, 2008, 13:38
Steve Middlesworth
Can anyone tell me if this is a dial to convert a hunter movement into a standard case? I have seen these before as well as the so called "sidewinders" and was wondering if this was the way around a stem being next to the "3"
Seconds on three
April 24, 2008, 13:43
Steve Middlesworth
Lindell,
You should be proud....I got the URL thingy to work.
Steve
April 24, 2008, 19:45
Frank Kusumoto
Conversion dials are fairly common. Any metal dial can be re-dialed so that it is a conversion dial. It seems these conversion dials at one time were fairly easy to buy on the aftermarket.
April 24, 2008, 21:27
Steve Middlesworth
Frank,
Thanks for the info. I won it for about $4.25 plus shipping. I'll put it on the shelf labeled "novelties, what in the world?" I am sure someone will ask.
Steve
April 25, 2008, 12:23
Marty Bell
Steve-I just had to comment on your "Novelties" shelf-that's a good idea...mine might get crowded quick!
Marty
April 26, 2008, 09:11
Steve Middlesworth
Marty,
I enjoy buying old shipping tins and movement containers, especially the double sided glass Illinois ones. I am trying to get one of each size. They sit on the shelf above my monitor and someday I will build a glass fronted display cabinet for them. They look really neat with an old movement sitting in them. So far I have three of the sixteen size and couple of small ones about an inch in diameter (size 6 maybe). I have an 18 size that is more like a tin so I am guessing they were made for the much older movements before the glass ones were available. Very interesting items from the horological past.
Steve
April 27, 2008, 06:33
Marty Bell
Steve-I was just checking the "Search" for info and you'd be amazed at some of the stuff on salesman's cases...I think you'd like it.
Marty
