June 02, 2007, 21:26
Robert SchusselMost accurate Elgin RR made
Below is my most recent Railroad purchase. The watch is in its original package
and the train is about 2.5 inches long and 2 inches high.
The watch was $1.99 and Postage was $10.15
Does anyone know when it was made or who made it.
Bob
June 03, 2007, 00:56
Matthew E. SuttonI dunno, but the seller has some very interesting inventory...
June 03, 2007, 14:05
Sheila GilbertIf I'm not mistaken, from the script, it looks like a new item. The latest ones coming out today have the name Elgin written like that, but of course, you would have to check the movement to see if it's battery or wind.
Most of the new ones are designed to have the watch part come out for changing the battery, so you can try to take the watch out of the train by prying it at the ridge of the train and watch. Shouldn't hurt it at all.
Either way, the watch should be able to be removed from the train for a closer look.
I have seen a lot of this type of new watch and some of them are so fun. I really like the train!
Good luck.
June 03, 2007, 14:15
Robert SchusselShelia
Thanks
I do know that it is a quartz movement thus the claim of the most accurate Elgin movement available.
When I get it I will give people an update.
Bob
June 03, 2007, 20:00
John ArrowoodThe movement is most likely of Japanese or Chinese manufacture. LaRose had these small snap-in fit-up movements in their catalogs for a few years; both the movements alone and in cases. I think Target had a selection of small clocks with similiar movements branded Timex.
June 03, 2007, 21:38
Joseph T. CollinsIf the movement is Chinese, and I suspect it is, it may not be as accurate as you hope. The Chinese seem to have a problem getting their crystals to oscillate at the proper frequency and make no provision for adjustment like is found in Japanese movements. I have a Chinese made quartz "Gruen" wristwatch that doesn't run as accurately as my Elgin model 571 B.W. Raymond.
JMO
Joe
June 04, 2007, 16:41
Robert SchusselShould I demand my $1.99 back if the watches accuracy is less than an Elgin grade 571?
Bob
June 04, 2007, 21:59
Joseph T. CollinsBob,
You are the one that titled this thread "Most accurate Elgin RR made" so if it turns out that it is not that accurate you will have to decide on asking for your money back.
My comment was on the Chinese apparent inability to get their quartz crystals to operate at the required frequency. I have had several time pieces of Chinese origin that have failed to keep accurate time.
A broken watch is correct twice a day but a watch that gains or loses is only right when they are being set!!
Joe
