Info needed on unknown 18 Size Pocket Watch Case
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/5603903277
May 25, 2012, 22:59
Douglas D. Weaver
I found this pocket watch case in an antique mall. It is hinged-front and snap-on back. There is no brand name or indication of what it's made of, only a serial number. It is apparently for a lever-set movement, since the crown doesn't pull up. Has anyone seen a case like this? Any idea who made it - and of what? The cut-out for the lever is at 2:00. From the backside, the case screw marks are at about 2:00 and 7:00. Any idea what brand movement might have been in it?
Thanks
Doug
May 25, 2012, 23:00
Douglas D. Weaver
Stem
May 25, 2012, 23:00
Douglas D. Weaver
Inside back cover
May 25, 2012, 23:01
Douglas D. Weaver
back cover
May 25, 2012, 23:01
Douglas D. Weaver
I neglected to mention that it is 18 size.
May 26, 2012, 11:30
Excepting the lever cut, I was guessing an early Ingersoll. A picture of the case screw marked side of the body might help.
May 26, 2012, 14:25
Douglas D. Weaver
Case screw side:
