August 07, 2014, 04:18
Paul D. TrombleyInteresting Elgin Dial 16S Arabic, Red 5 Min outer, sub second, no feet
I understand no feet dials for the doctor watches with a center seconds hand... but don't quite get it for a sub seconds movement.
This one left the manufacturer with no feet as evidenced by the original locations being glazed and fired with the original back.
August 07, 2014, 04:19
Paul D. Trombleyand the front, regrettably, light hairlines out from center up toward ten and one.  They don't show up until I zoom with the right light.
August 07, 2014, 15:30
David AbbeMake it into a BOLA! Seriously, there are some "feet kits" which have these rivet-like thingys you can solder to the dial. Takes some effort and may damage the dial more. If you do a Bola, put on a "smile" and you will help make someone's day.
August 07, 2014, 20:23
Paul D. TrombleyDang... I was hoping there was some obscure snap fit dialed Elgin out there.  I've worked on the snap fit Howards...
A bola might work... a bit too big for ear rings.
