Waltham Vanguard balance staff "Click" to Login or Register
Picture of Fabrizio Di Claudio
Hello, i have a Waltham 16s Vanguard, serial number is 31245652 with broken balance staff, how i can find type/description and buy it?
Fit with normaly balance staff of 16s Waltham?
Thank you!
Posts: 77 | Location: Torino in Italy | Registered: January 23, 2008
IHC Member 365
These are friction staffs, used with detachable hub, not the usual riveted type. Two types of shoulder, straight (factory #4860) or tapered (factory #4861). Still generally available.
Posts: 657 | Location: St Paul, Minnesota in the USA | Registered: May 04, 2004
Many Thanks William, i try serch on the web.
Fabrizio
Fabrizio, Send an e-mail with a photo of the broken staff to Brian Cavenaugh at;
pwpartsetc@pwatch.com
He should have one of these you can buy.
Hello David!! I buyed today that balance on ebay item n° 300327413312 i think is the some of my, colored blue staff, from german seller.
How i can remove broken staff? I read using only staking tool ( absolutly no lathe ) and put it again with staking tool again. Balance of Vanguard, how say William Thomas, is frictioned, i understand with pressure, no riveted.
Correct? Thank you!
Fabrizio, This is copied from my first Edition Fried. I Hope it helps.
Other things to consider when replacing the staff:
1. Many staffs with the same number have several pivot sizes available. It is important to get the right size to match the jewel holes.
2. Install the staff by itself in the movement before putting it on the balance wheel to check for end shake and freedom of movement in the jewels.
3. After installing the staff, replace the roller table and poise the balance.
4. Install the hairspring and check for good balance motion in all positions. I like to see the balance oscillate for at least a full minute and come to a nice gradual stop with no jerking action.
5. Put the balance in beat by centering the roller jewel between the banking pins when the balance is at rest. This is done by rotating the hairspring on the staff at the collet. If you made a drawing of where everything was before you started and put it back in the same place you should be very close.
If this were a riveted, rather than friction staff you would put the balance on a lathe and cut the rivet with a graver. Driving out the rivet without cutting first will ruin the hole in the balance arm.
Roger
COOL!!! Big Grin
Thank you very much David for book image and Roger for interesting info.
I removed broken balance staff, i have one taper sh #4861 but is not the some type of broken balance staff.
Which is correct factory? Seems a modified balance staff.
Thanks!
As your Waltham is a 1942 production year Vanguard, it has the solid wheel and Elinvar Hairspring, so the new staff you got was correct. The new staff is a "Press fit Staff" which is installed into a Blued steel hub that is pressed into the Waltham wheel for that purpose.
Your pictures of the broken staff you removed and the balance wheel you are trying to fix with the new staff show the last "service" to this watch was to crudely "revise" an old type "rivet" staff to "fit" in the wheel.
But it is not clear that the Blued steel hub is still in the wheel. As the blued steel hub is required for fitment of the CORRECT new staff you have in the picture. I hope it is still in the wheel. If it is not, I suggest you contact Brian Cavenaugh at;
for a used wheel you can take the hub from for this fix.
Thank you David!
Frown
Hello all!
Finally i fixed it, thanks to David and William for help Smile
I put the balance staff on staking tool..
Old and new balance staff
Testing without cleaned the movement
Disassembly and cleaning
Final test! Working again Big Grin
