November 19, 2015, 10:42
William SchlueterIllinois watch aficionados what do you think?
I have a 60 hr Bunn that is in a model one case but marked 29. Could this be a factory error? Would like to hear your opinions. All numbers match so it isnt a a wrong back.
November 19, 2015, 10:45
William SchlueterClearly marked m9del 29 in correct font
November 19, 2015, 11:00
Lorne WasylishenYou pretty well have to go with factory error but hopefully Buster will chime in with his vast knowledge.
In the meantime here is a good bit of info on
Illinois 1st Model Case HistoryNovember 19, 2015, 12:31
Buster BeckThank you. In our Illinois data base we only have 7 of these mis-marked cases entered to date between 1928 and 1929.
https://ihc185.infopop.cc/eve/f...1029912/m/8281069912 These are scarce if not rare and require more $$$$ to get one unless you stumble across one that someone is unaware of
November 19, 2015, 14:24
Robert Lee MillironNew man on the job. Stuff happens.
November 19, 2015, 15:45
William SchlueterThis watch is complimented by the correct box,bag and papers. One of my best!
November 20, 2015, 15:04
William SchlueterSet... hope this is of value
November 21, 2015, 22:16
Steve MiddlesworthIf not for the box I would have said in all likely hood this would not have been an original combination. It seems this movement got pushed back in the vault and forgotten as it is from 1927 and ended up in a 1928 case, a late 1928 it appears as well. Very interesting set.
November 22, 2015, 07:31
William SchlueterWas received as a Christmas gift in 1928. $65.00 had to be a chunk of money in 1928
November 22, 2015, 19:22
Larry LamphierNotice that the case number is off one digit?
On the case it ends in an 8, and on the box and tag it ends in a 9.
November 22, 2015, 20:13
Roger StephensYour right Larry.Another mystery?
Roger
November 22, 2015, 21:02
Kevin Hoffmanlooks like that one just has errors following it , I still think that 65.00 in 1929 was really something .
November 22, 2015, 21:47
Roger StephensCase stamped in error.Case number wrong on hang tag=Monday morning hangover.A comedy of errors.
November 23, 2015, 18:32
William SchlueterWonder if the turmoil of hamilton taking over played into it. Or if was just good scotch
November 23, 2015, 20:47
Robert Lee MillironEmployers didn't have drug and alcohol testing in 1928.
November 24, 2015, 22:05
John WatkinsThat watch was a nice Christmas present -- $65 in 1928 is about $900 today, according to the Department of Labor's inflation calculator.
December 02, 2015, 18:37
William SchlueterThanks everyone for your input. Especially you Buster with your input of how many are known to exist.
December 03, 2015, 09:38
Buster BeckThanks, but let me be perfectly clear
how many are known to exist is
"UNKNOWN". IHC185 and our membership have discovered 8 [which includes yours]. It will be a small number, but there are
NO factory records to help us, so what we and others "discover" along the way will be helpful to add to our database.
If you have a Bunn Special in one of these mis-marked cases, feel free to let us know in this thread.
