Unusual B.W. Raymond Model 9 17j Question? "Click" to Login or Register
I usually don't pay much attention to the "typical" BWR watches. This example, however caught my eye as it was a model 9 3f bridge. I have seen lots of the grade 280, but never this B.W Raymond version.
Posts: 105 | Location: Phoenix, Arizona USA | Registered: December 20, 2005
Here is a close up of the serial #
Was this a common production?
Any advertising seen?
Best regards,
Sean
Here is the information from the Elgin Watch Colectors Site.
Serial Number SN Range Quanty Name Year grade size code jewels Adj/reg/etc.
10855402 10855001 1000 BWR 1903 280* 16s obn9l 17j Adj
last run of grade 280; only produced for 2 years;
7402 of 8000 in grade;
# 1950 MC says double roller starts at 10885201
grade total runs first yr last yr class size code jewels Adj/name
280 8000 5 1902 1903 102 16s obn9l 17j Adj / - BWR 280
(*) notes on grade 280: Marked: None, BWR or 280. bridge
Class 102: 16s OF 3/4 lever
280 8000 made model 9 bridge 17j Adj Marked None, BWR or 280.
361 1000 made model 13 17j A5P Marked BWR.
370 7300 made model 15 17j A5P Marked BWR.
I have observed several 280 in the lower serial # ranges, but how many are marked BWR, was this random or did they mark blocks of them as 280 or BWR?
Welcome Aboard Sean!
My belief is that none of the three finger bridge Raymonds are very common watches. We got into some of these a while back here in...
Chris Abell's "Elgin 3F Bridge Question"
I think you may find that topic interesting reading.
Thank you, Lindell
I had previously read the posts you recommend, however these posts do not seem to offer any info relating to the production quantities of the actual BWR marked 280 movements.
What methods of research would you recommend to determine/hypothesize the actual production Qty's of the BWR marked 280 movements?
Sean
RR Watch Expert
Picture of Ed Ueberall
I took a quick look at both the database that Kent Singer & I maintain and at Wayne Schlitt's Elgin site. From the combined data, it appears that only the last run, 10,855,XXX was marked "B. W. Raymond". The other four runs, totalling 7,000 movements were either marked "280" or had no grade name or number engraved.
Ed Ueberall
IHC Member 34
The Escapement
Picture of Sheila Gilbert
There were 1000. If you go to Wayne's Elgin site and in the search you type
G=280
(Also notice that in the last row it shows the BWR Grade 280 as 1000)as Ed said they started at 10855001
G=280 you will see this.
10073001 10073001 1000 280 1902 280* 16s obn9l 17j Adj
first run of grade 280; only produced for 2 years;
1 of 8000 in grade; 4001 of 9th model in 16s
10126001 10126001 3000 280 1903 280* 16s obn9l 17j Adj
10192001 10192001 1000 280 1903 280* 16s obn9l 17j Adj
10246001 10246001 2000 280 1903 280* 16s obn9l 17j Adj
10855001 10855001 1000 BWR 1903 280* 16s obn9l 17j Adj
# 1950 MC says double roller starts at 10885201 total watches found: 8000
http://elginwatches.org/cgi-bin/elgin_sn?sn=G%3D280&action=search
Sheila
Sheila,
Thank you very much for the additional info. I had only used wayne's site as a serial # look-up which does not break out the last run of the 280's
When I searched the Grade 280, it of course does show the individual runs of the 280/BWR....I learn something new everyday.
I will from now on, use serial # and actual grade type when using Wayne's site.
Thank you,
Sean Plummer
Sean,
If you go to the URL below, it will show you all the ways you can search.
However, you must type it exactly the way it says, or it will not work. No spaces.
eg. if you type n=BWR you will get all information on BWR's
Check out all the other things you can use to do a look up. Nice! Good Luck!
http://elginwatches.org/databases/search_options.html
Sheila
