May 03, 2008, 13:27
Larry BuchanPlastic Pocket Watch Crystals
what year did they start using Plastic Pocket Watch Crystals?
May 03, 2008, 14:32
David AbbeLarry that is a real can of worms. Celluloid Plastic was actually in use before 1900. Molded plastic came into being in the 1920's. Then you have some other cellulose derivatives that could have been used even earlier.
One thing is for sure, the later very hydroscopic acrylic lenses ruined the hands over time because they were permanent "humidifiers".
So MANY TIMES a watch comes in with a perfect movement, an old yellowed out lense and sticks of rust for hands.
May 03, 2008, 18:05
Larry BuchanThanks Dave nothing works worse than a pocket watch with a sickly green crystal, and the loss of hands that are hard to replace makes it even worse
May 04, 2008, 09:20
Sheila Gilbertsticks of rust for hands!!!!
lolololololol
I love that, I have a few too!
May 05, 2008, 13:09
Robert SchusselMy advice is that if a crystal is yellow or green in color get rid of it ASAP
Bob
May 06, 2008, 14:29
Edward KitnerHow can you tell the difference between a glass vs plastic crystal?
I tried the old, tapping with the finger nail trick but my hearing is terrible and I can't tell much difference.
Thanks
May 06, 2008, 16:21
David AbbeGenerally the plastic crystals (left side picture) have a softer "roll" at the edge radius, while the Glass (Right side Picture) has a Bevel, or No "roll" at all.
May 06, 2008, 19:52
Edward KitnerLindell tried to walk me through this today. I am still now to sure what I hear when I tap on it. Maybe this pic will help.
May 07, 2008, 06:18
Marty BellMy personal favorite has always been tapping the crystal on a tooth ( a real one ,of course!
), the "ting" is almost always unmistakable.
May 07, 2008, 07:22
Brian C.If you really can't tell if the crystal is glass or plastic, take a pin and try and scratch a little bit of the crystal, in a place that won't be seen. If the pin leaves a scratch, the crystal is plastic, if not, it's glass.
Brian C.
May 07, 2008, 12:07
James H. Millerthis may sound odd but i tell by feel to me glass feels cooler to the touch then plastic.but then you have to play with a lot of crystals to get the feel.
