Fahys Oresilver No. 1 Clam Shell Case: When was it made? "Click" to Login or Register
IHC Member 1610
I was going though a bunch of old cases I have in a box and I noticed this one case only had one hinge and it was on the bezel I thought to myself that was odd. I looked at the back of the well worn case and the back did not unscrew. Odd again.
After examining the case I realized I have a clam shell case. I had actually never seen one in person before. I checked the tag and I purchased it in 2010 for $11.50.
It is a size 18 Fahys Oresilver No.1 case sn#L8901 pat. April 5, 1881. It also has a #3 above the SN.
Can anyone tell me when this case was made? I would like to put a period correct movement in it.
Harry
IHC Member 1610
#2
IHC Member 1610
#3
IHC Member 1610
#4
IHC Member 1610
#5
IHC Member 1610
#6
Site Administrator
Picture of Phillip Sanchez
I moved it for you, Harry
Interesting post Harry. I have one like it as well and could never decide exactly what movement would be correct ( how late a movt. would be correct ? )
Mine is SN W6908 also 3 oz. But mine is plain
with no engraving. My has 2 patent dates
April 5 1881 & April 22 1884
I hope someone can tell us how " new " of a movement would be correct. Jack
Posts: 352 | Location: Southeast Michigan in the USA | Registered: March 22, 2012
IHC Member 1610
Thank you Phil.
I hope so too Jack. Any movement should fit but I would like it to be period correct if possible. I also hope I have a pendant set because you need a pry bar to open this thing.
This is often referred to as a "Paired Case" and it has been my experience that these were done for only a short while in the 1880's and 90's due to the more versatile (and cheaper) "swing ring" design which flourished through about WWI time.
Normally the best I have ever been able to do is look at sales catalogs and see what they show in the way of cases. In this case the best proof of age time frame is after keywinds since it does not have a hole for the key. After 1881 from the patent date, and probably before 1905 since around that time the French bow types started to become more popular and the style of the stem was different. I would not have any problem putting a movement from 1881-1899 into that case, who the heck is going to say your are wrong. A bit after 1910 18 size movement were going the way of the doo doo anyway.
IHC Member 1610
Thank you David and Claude Those answers seem to fit and make a lot of since. There you go Jack I think we have a answer.
Now to work on the edge dints some more, polish it, find a bow and glue in a crystal.
Thanks All. Yea, I think that's right....
I'll try to put a Pre-1900 Movement in it .
David ... I HATE swing out Cases. To hard to view movement.
Jack
I looked at the Elgin site and in a 1903 sales catalog they were still showing Swiss watches with cases that looked a lot like this one. Actually with all of the scraping going on these silveroid are really picking up in prices.
IHC Member 1610
Yes some day you will be lucky to even be able to get a silveroid case.
