January 11, 2017, 15:39
Elzie J. WilliamsBunn Special Case Model 181 Question
I have a YGF BS case model #181, case #680415 that needs a movement. What would be the correct range of serial numbers for movements (21 or 23 jewels) to put in it? Thanks, Jack Williams
January 12, 2017, 18:49
Elzie J. WilliamsLindell, thank you so much for the very good information. The case is in excellent condition and I wanted to be sure the movement was time compatible for it and with your info I'll be able to. Thanks again!
