Ok how many quick fixes can you spot "Click" to Login or Register
Certified Watchmaker
Picture of Chris Abell
This is going to be one of those watches, some ***** been hacking away at a once perfect watch, Frown I can repair it all but will not be cheap to reverse this mess, can you see any? photo not the best
Picture of Robert V. Jones
Hard to see but is the fork where it fits into the roller jewel broken on one end. pivots on staff look broken. SOmeone wrote on dial. Is that a stand at bottom of dial or did someone get hungry and take a bite out of it. Also hard to see but a couple of the jewels look cracked.
Site Moderator
Picture of Tom Brown
I don't recall seeing so many holes in a 4992B but maybe I didn't pay that much attention, is that a balance screw broken off at it base?
I thought the same thing Tom but I never took one apart only know from what I seen on other watches. I thought at first screw was broken but looks like you can see through the hole at the staff.
Chirs someone does not know how to read military time huh they added 1-12 then 1-12 again I hope they didnt scratch the dial and it cleans off easy.
So far, the “budding watchmaker”
• carried out a quick dial conversion to pick up the missing 1-12 hrs but no AM –PM markings, shoddy should have added those also.
• Pallet fork damage when trying to fit a new pin, so filed the top down a little also no doubt bent it then glued the rest in.
• When re assembling threw the gears in place and screwed the plates down, don’t worry as it tightens they punch new holes in the jewels.
• Same process with balance staff upper and lower shot
• Then to time the watch, filed heads off like slices of cheese the best one is he filed the meantime screw head down on one of the matched pair, and of course a good dollop of super glue to the roller and everything else around….
So that is only the first look I am sure more problem await…..
Should have bought my 4992b watch for parts. Look at this LOL I should have sold it as a rare split seconds.
I had one of those in also a couple of weeks ago complete with wobbly wheels and bent shafts!
Still not sure how he did this one, I can only figure lifting the plates while fully wound and letting the barrel teeth slide across the center wheel. Eek Roll Eyes
Isnt that what they call wolfs teeth winding Big Grin
Picture of Mark Cross
Well, bent shaft, wobbly wheels and all, it's still keeping perfect time absolutely to the very second of being reset last Tuesday, so even in questionable condition they keep perfect time after leaving Chris's bench. Wink
Still, I don't know why you're fighting that one! It's a mess! Confused
Regards! Mark
IHC Member 376
Watchmaker
Picture of Samie L. Smith
Wow what a mess sounds like you have a set of plates and not much else too work with. Smile
Well looks like I have success on this one finally, I spoke with the owner and said it wasn’t going to be cheap and he said to go ahead, it took far longer than expected but so much time invested in it could not abandon it by then, so far it running well now, will need a few days to be sure!.. Mark, good to hear yours is also working now that’s another one rescued Smile
