Bezel question on 12s hinged case
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/2843931467
July 21, 2011, 16:26
Paul Arsenault
I have a Hamilton 12s case that when the dust cover is snapped shut the bezel springs open. Any type of adjustment possible to cure this? Thanks..Paul
July 21, 2011, 17:54
Hi Paul,
Without having it in-hand this is a difficult diagnosis.
Sounds like the case is somewhat sprung or the bezel is worn and incapable of closing tightly any longer or a combination of problems. Trying to slightly reform the case by hand might help, but you could also pop out or break the crystal. We can no longer just find another case, every worthwhile case should be properly repaired and saved. If you want it fixed correctly and to avoid possible future problems you could send it to Leon Harris, an IHC185 Member who has a solid reputation of doing fine case repairs.
Check our IHC185™ Members Business Directory for Leon and others who provide excellent services. Here's a link to some interesting information about Leon Harris...
CLICK HERE FOR: Watch Case Repairs? Call Leon Harris!
You may contact Leon at HarrisLJ@msn.com or phone 931-261-0543
Those are my thoughts, let's see what others say.
July 21, 2011, 19:36
William Thomas
An old watchmaker's trick I learned was to lay a piece of string along the hinge and close the cover over it. This bends the cover down very very slightly and can make catch hold the cover a little better. This works if the problem isn't too severe.
July 22, 2011, 10:05
Paul Arsenault
Lindell & William: Thanks for the response. I did apply a little pressure to the bezel and now it is flush with the case and closes properly. The crystal has been removed and i'm waiting for one from Mike. Thanks for your help. Paul
